Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919405members
1223701discussions
Community Activity
Resolved! PSA: Avoid CBS350 Switches - Critical POE Defect
Hello Community, I'm writing to let you know that there is a critical POE defect in the CBS350 switches and you should avoid them if you require stable POE operations. This apparent software defect causes POE ports to randomly fault after 8 to 12 hou...
d0nni3q84 by Level 1
  • 18240 Views
  • 52 replies
VPN credentials not received after sanbox reservation
Hi there,I tried to reserve 3 times "Open NX-OS Programmability AlwaysOn" Sandbox. However, I do not receive any VPN Credentials to connect to it. The first email I receive mentions that I will receive a second email with your lab’s access credential...
Is this NAT configuration avaiable in ASR 9001
We have ASK 9001 Is this NAT configuration available if not what is the alternate configuration? we are trying to setup a PPPOE configuration in ASR9001 and configured DHCP pool, BBA . how to add nat inside and outside configuration for the authentic...
How To Connect with Allegiant Air? {{Contact Us™!}}
How can I speak to an Allegiant Air representative fast? Talk to someone on Allegiant Air smoothly, give their dedicated support line a ring at +  ퟏퟖퟎퟓ ퟑퟎퟗ ퟗퟑퟕퟕ . Take your time and listen carefully to the automated prompts, then share all the requir...
PPPOE configuration on asr9k
Team,,We need to do below similar configuration of ASR1002 in our new ASR9001 please supportip dhcp pool PDY-3network 30.23.0.0 255.255.0.0default-router 30.23.2.1dns-server 8.8.8.8 4.2.2.2bba-group pppoe PDY-3virtual-template 3sessions per-mac limit...
Resolved! Unable to upgrade Sandbox to full version
I have sandbox access but want to upgrade so I can test RCS capabilities (amongst other things).  When I click on "Request full access" it takes me to this: https://imimobile.com/products/imiconnect/sandbox/request-upgrade which gives me a cant reach...
jakehova by Level 1
  • 144 Views
  • 4 replies
Replacing Juniper GWs with Cisco
Hello Everyone. I am working on replacing juniper GW(production)switches with C9500’s. Those junipers are in active standby.My approach is pre-stage cisco switches copy configs from juniper to cisco. Here one question is juniper GWs are using vrrp fo...
aziel51 by Level 1
  • 18 Views
  • 1 replies
ESA file analysis (AMP) lost emails
Hello community,  we have HW cisco with HW Threat grid integration. The problem that we have is when the file is send for analysis the message is quarantined in File quarantine. I checked that the Threat grid needs 5-10 min to finish the analysis, af...
