microsoft vpn client and cisco router
Jan 30th, 2007
Has anyone been able to access a cisco router via the microsoft client and not pptp but ipsec?
Daniel Voicu Tue, 01/30/2007 - 08:38
That client you are talking about is L2TP/IPSEC client.
I have done a connection using the windows client but with a Cisco Concentrator:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a0080094aca.shtml
For a router check:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804dfa69.html
The main problem is that if you are behind a NAT/PAT device the L2TP (that checkes the header) will discard the packets. It appears IOS 12.4 corrects that.
Please rate if this helped.
Daniel
Andy Robinson Tue, 01/30/2007 - 08:45
It should work, but I have not done it personally. I have seen documentation from Linksys that shows how to configure Microsoft IPSEC to do a remote access VPN tunnel to a Linksys VPN router as they don't have their own client (or at least didn't). I think the model was a BEFVP41 or something like that, so it might be worth downloading the manual off their website and looking throught it. HTH
