APs from remote site loosing connection to WiSM
Jan 30th, 2007
All,
we have one WiSM which controls APs over two physical locations (they are interconnected with a VPN tunnel). This works like a charm. Well, when it works :D.
The problem is that at night sometimes all remote APs disassociate from the WiSM and have trouble to find the WiSM back on the next day.
Is there any form of keepalive or so which I could configure?
--Joerg
aghaznavi Mon, 02/05/2007 - 08:17
You don't have to configure any keep alive to keep the APs registered to the WiSM. Once the LAPs are registered they will stay registered as long as the WiSM is active or as long as the LAP is reset. If it is getting disconnected often, we have to look at the error messages and debugs to identify the root cause. Can you enable debug lwapp events enable and debug lwapp errors enable commands on the WiSM and see the messages that you get when the LAPs deregister from the LAP?
ksannedhi Mon, 02/05/2007 - 10:24
Also look at the log information on the remote APs to find out what is causing them to reboot.
Is there a power issue at the remote location? What is the uptime on the switch to which these APs are connected?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
