SSH Login
Jan 30th, 2007
I have an ASA 5510 and when I go to test the SSH I am getting a password authentication failure. My password works with telnet and ADSM. I have tried the default login, I have tried to use the enable password and I have completely removed the password from one account I setup for testing and get the same issue. I also have tried to connect on 4 different PCs. Is there something that I am missing on the config?
rkretzschmar Tue, 01/30/2007 - 08:35
Thank you for your help. They were the docs I was looking for to check my config. It is working now. I appreciate the help.
