Debug output for Tunnel failure
Jan 30th, 2007
What does it mean when the debug output shows "retransmitting Config Mode request"??. I am trying to deciper the following message from a client's PIX 501 Firewall. I have been running "debug ipsec sa" and "debug isa sa" on the PIX as I attempt to build a site to site tunnel to a remote location.
What does the attached output mean to me?
return status is IKMP_NO_ERROR
crypto_isakmp_process_block:src:74.93.118.41, dest:70.89.234.69 spt:500 dpt:500
OAK_MM exchange
ISAKMP (0): processing ID payload. message ID = 0
ISAKMP (0): processing HASH payload. message ID = 0
ISAKMP (0): SA has been authenticated
ISAKMP: Created a peer struct for 74.93.118.41, peer port 62465
ISAKMP (0): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
ISAKMP (0): Total payload length: 12
ISAKMP (0): sending INITIAL_CONTACT notify
ISAKMP (0): sending NOTIFY message 24578 protocol 1
VPN Peer: ISAKMP: Added new peer: ip:74.93.118.41/500 Total VPN Peers:2
VPN Peer: ISAKMP: Peer ip:74.93.118.41/500 Ref cnt incremented to:1 Total VPN P
ers:2
OAK_QM exchange
ISAKMP (0:0): Need config/address
ISAKMP (0:0): initiating peer config to 74.93.118.41. ID = 1019677185 (0x3cc70a
1)
ISAKMP (0): retransmitting Config Mode Request...
ISAKMP: phase 2 packet is a duplicate of a previous packet
ISAKMP: resending last response
Andy Robinson Tue, 01/30/2007 - 08:35
It might be caused by IKE mode config if you have remote access VPN connections on the same PIX. It might be worth adding "no-xauth no-config-mode" to the end of the isakmp key for the site-to-site tunnel to disable extended authentication and IKE mode config for that particular connection.
