Encounter Error while Installing of ACS 4.1 from ACS3.32
Jan 30th, 2007
Would appreicate input as currently I encounter error message " The existing installation was no removed correctly, Do you want to try again or abort this installtion" What is the souldtion as I retry the same message appear,
MC
vmoopeung Mon, 02/05/2007 - 08:17
Try these steps
Go to System Configuration, System Control.
On the Services Log File Configuration, check Manage Directory and select "Keep only the last ____ files" . Change the value of this parameter from 7 to 3.
After changing the value, hit Restart.
Trending Topics - Security & Network
