01-30-2007 09:06 AM - edited 03-09-2019 05:18 PM
I'm using syslog from a 3005 and I'd like to add log entries for login success, failure and logout/disconnects. Ideally it
would record account and ip address. Could anyone help me craft the rule for these events (or point me to some helpful exampe).
thanks
02-05-2007 08:26 AM
Click the Events to Syslog drop-down menu button and choose the range of event severity levels to send to a syslog server by default. The choices are: None, Severity 1, Severities 1-2, Severities 1-3, Severities 1-4, Severities 1-5 and Use Event List. The default is None. Using the default means that no events are sent to a syslog server. If you choose Use Event List, configure the Event List to specify the event types to send to the syslog server.
For more information refer the url,
02-22-2007 09:24 PM
I ended up using configuration/system/events/classes and added class names for auth and ike for severity 1-4 to the
syslog server. This is giving me what I needed.
thanks.
John
