7941G Local Speed Dial Directory
Jan 30th, 2007
I created the speeddial.xml file per the sys admin guide, loaded it up on our test lab and all looked fine.
Select the hard "directories" button and display reads:
--missed calls
--recieved calls
--local directory
--local speed dial
--personal speed dial
Select local speed dial and all entries show. So I uploaded the same file to a remote site production router which (to the best of my knowledge) is configured the same as my lab. But the user states that she only gets the first three options --missed calls, --recieved calls, and --local directory.
I've checked and compared everything I can think of.
Any suggestions?
2811 Router
12.4(4)XC4 IOS
4.0(3) CME
7961G/41G, and 7912G phones
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:term61.default.loads
tftp-server flash:term41.default.loads
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:cp7912080001sccp051117a.sbin
telephony-service
no auto-reg-ephone
load 7941GE TERM41.7-0-3-0S
load 7941 TERM41.7-0-3-0S
load 7961GE TERM41.7-0-3-0S
load 7961 TERM41.7-0-3-0S
load 7912 cp7912080001sccp051117a.sbin
max-ephones 36
max-dn 108
ip source-address 192.168.121.1 port 2000
calling-number initiator
service phone videoCapability 1
system message Yakima PCLI
time-zone 5
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name Administrator secret 5 $1$OH7w$v.9DQLA6CJCmASyxCM73O0
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files version-stamp 7960 Jan 30 2007 10:03:46
Thanks!
Michael
Paolo Bevilacqua Tue, 01/30/2007 - 11:17
Hi Michael,
I also had problems with directories on the 7912, in my case, the local directory was missing. I've updated to the latest image and since then everything is fine. The image that I use is
CP7912080002SCCP060817.sbin
Let us know if that fixes the issue for you.
Paolo Bevilacqua Tue, 01/30/2007 - 11:42
Indeed, the various phone images have bugs and for the 7912 problem, that was the only thing that fixed the issue. I use 8.x versions without issues.
But a problem that I have with _all_ the images on 7911/41/61, is that external placed calls always show as 'unknown' in the directory.
I think the cisco 'recommendation' on the 7.x firmware is not really a mandatory one, given that 8.x images are listen in the compatibility table, and in the CME download area is now released a file that contains all 8.x firmware for the ephones.
