IP cache issue
Jan 30th, 2007
My two 6500 run in redundancy, with vlans balanced between them. One cat has the following cpu load:
RJ6509_1#sh proc cpu
CPU utilization for five seconds: 36%/32%; one minute: 47%; five minutes: 42%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 4 10 400 0.00% 0.00% 0.00% 0 Chunk Manager
2 1888 32256 58 0.00% 0.00% 0.00% 0 Load Meter
3 152 517 294 0.00% 0.00% 0.00% 0 Constellation Ba
4 652700 42788 15254 0.00% 0.29% 0.24% 0 Check heaps
5 4 39 102 0.00% 0.00% 0.00% 0 Pool Manager
While the other:
RJ6509_2#sh proc cpu
CPU utilization for five seconds: 17%/14%; one minute: 17%; five minutes: 19%
1 0 12 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 2152 55274 38 0.00% 0.00% 0.00% 0 Load Meter
3 32 513 62 0.00% 0.00% 0.00% 0 Constellation Ba
4 692184 54482 12704 0.24% 0.21% 0.23% 0 Check heaps
5 16 62 258 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
When I issue "sh ip cache" on the primer, that is what I see:
RJ6509_1#sh ip cache
IP routing cache 3 entries, 528 bytes
2994 adds, 2991 invalidates, 0 refcounts
Minimum invalidation interval 2 seconds, maximum interval 5 seconds,
quiet interval 3 seconds, threshold 0 requests
Invalidation rate 0 in last second, 0 in last 3 seconds
Last full cache invalidation occurred 21:43:47 ago
Prefix/Length Age Interface Next Hop
200.150.148.80/30 01:00:40 Vlan14 200.150.148.76
200.179.200.0/24 00:05:33 Port-channel3 200.155.20.90
201.36.206.0/24 00:04:41 Port-channel3 200.155.20.90
While the second one:
RJ6509_2#sh ip cache
IP routing cache 131 entries, 23948 bytes
13777 adds, 13646 invalidates, 0 refcounts
Last full cache invalidation occurred 3d04h ago
Note that the first with higher cpu usage, only has 3 entries, while the other has 131 entries.
The configuration on both is the same. Can it be a hardware problem ?? What can it be ??
lgijssel Tue, 01/30/2007 - 13:54
As a first step, you should check the complete output from "sh proc cpu" to see which process is actually taking the most cpu. This will give a first impression of the direction to search in.
Leo
felipe.oliveira Fri, 02/02/2007 - 10:52
I guess I'm having a loop problem in the network. I just put a certain vlan in shut and the proc cpu went down imediatly.
Thank you
