7941G Time Display
Jan 30th, 2007
I've read some past posts on this topic and most suggested verifying firmware and loads. We are using 7961G, 7941G, and 7912G. The one and only 7912G has the correct time.
Any other suggestions?
2811 Router
12.4(4)XC4 IOS
4.0(3) CME
7961G/41G, and 7912G phones
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:term61.default.loads
tftp-server flash:term41.default.loads
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:cp7912080001sccp051117a.sbin
telephony-service
no auto-reg-ephone
load 7941GE TERM41.7-0-3-0S
load 7941 TERM41.7-0-3-0S
load 7961GE TERM41.7-0-3-0S
load 7961 TERM41.7-0-3-0S
load 7912 cp7912080001sccp051117a.sbin
Michael
Paolo Bevilacqua Tue, 01/30/2007 - 11:46
Time on the 7941 works fine me. I have a valid NTP association in CME router and the following under telephony-service:
time-zone 23
time-format 24
date-format dd-mm-yy
mchiaravalle_2 Tue, 01/30/2007 - 12:00
Hi, thanks for the quick response.
I'm not using NTP so the phones are pulling local time from that router, I guess. Also I have the exact setup here in our lab but no time problems here.
mchiaravalle_2 Fri, 02/02/2007 - 12:10
I ended up updating all the phone firmware loads to 8.x to try to resolve this and a speed dial display issue and the update seemed to take care of both.
Thanks all.
