01-30-2007 11:59 AM - edited 03-05-2019 02:04 PM
Hello.
I'm searching for routers which support the following specifications:
- Traffic Engineering
- CoS differentiator support
- MPLS
- Fast Reroute
I'd like to know which Cisco product is adequate for this case and do I need some additional network modules if want to test minimally mpls with routers (up to 3)?
Best regards!
01-30-2007 10:29 PM
Hi Jack
did u try product advisor tool available in CCO ?
if not can you try the below link...
regds
01-31-2007 02:24 AM
I've already seen the Cisco Router 3640, it supports all the features above. My question is, if I buy this equipment and an additional network module NM-16ESW, is it sufficient for supporting MPLS? Or do I need any other network module?
Best regards.
