Move from PIX to Cisco28
Jan 30th, 2007
I'm moving a VPDN setup from a PIX to a Cisco2801. However, what's the equivalent commands on 2801 to the following PIX commands:
vpngroup 1 dns-server VTelEXInside VTelNTInside
vpngroup 1 split-dns vermonttel.com
vpngroup 1 idle-time 1800
vpdn group 1 client configuration address local vpnpool
vpdn group 1 client configuration dns VTelEXCInside
vpdn group 1 client configuration wins VTelEXCInside
Moreover, can I do the local authentication on the 2801? I cannot find the commands to define the username and passwork.
sachinraja Tue, 01/30/2007 - 16:43
Hello philips,
Are you running 12.4 in your router ? If so, please find all the VPDN commands supported by 12.4...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hvpdn_r/vpd_t1_h.htm#wp1050563
See if this is of help.. what exactly are you trying to configure here ? PPTP ?
Note - make sure you have the sufficient IOS to run VPDN, otherwise, u will not be able to run the commands given above.. what is the present IOS in the router ?
Hope this helps..
Raj
philipsyao Thu, 02/01/2007 - 06:30
Yes, I'm configuring PPTP.
The IOS is 12.4, the actual output is like this:
2801 Software (C2801-ADVIPSERVICESK9-M), Version 12.4(7), RELEASE SOFTWARE (fc6)
However, I cannot find the command "resource-pool profile vpdn" and "resource-pool profile customer" commands.
Should I use a PPTP server to make it running? But why the PIX can do the local authentication of the firewall.
I can use the following command to define the remote users:
vpdn username scoleman password *********
vpdn username jmrobins password *********
