01-30-2007 01:29 PM - edited 03-18-2019 06:53 PM
Can Cisco Unity Connection be deployed in a failover Configuration. I am thinking of configuring (2) Cisco Unity Connection Box integrating directly to exchange server for Unified Messaging.
01-30-2007 03:56 PM
Unity Connection cannot currently be deployed in a failover configuration.
Unity does support failover, however.
10-01-2007 01:48 PM
What about Cold Standby can this be supported or will it ever be an option?
01-04-2012 04:17 PM
In unity connection the failover is called High availability which is better than regular Unity(windows based), because it allows both servers to answer calls.
01-04-2012 05:18 PM
I recommend you to review the documentation to fully understand how it works and what to expect with CUC
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/8x/design/guide/8xcucdg060.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-02-2020 04:38 AM
While configuring the serviceability alert triggered from from services from RTMT
Real-Time Monitoring Tool to send notifications for the following Cisco Unity Connection alerts:
AutoFailbackFailed
AutoFailbackSucceeded
AutoFailoverFailed
AutoFailoverSucceeded
NoConnectionToPeer
SbrFailed
