export map on a vrf
balavenkata
With the following config, does it export only the 10.2.3.3/32 route with
the 114.3.1.1:4 RT set ? Or does all routes from the vrf get exported
(because there is no set extcommunity statement below the
route-map) ?? My intention is to export only that route from the vrf..
ip vrf bv_1.135_fe.0.0.112-Hub
rd 135:5
export map bv_1.135_fe.0.0.112
route-target export 114.3.1.1:4
route-target import 114.3.1.1:5
route-map bv_1.135_fe.0.0.112 permit 1
match ip address prefix-list bv_EVpn1-bv_1.135_fe.0.0.112-Hub
ip prefix-list bv_EVpn1-bv_1.135_fe.0.0.112-Hub seq 1 permit 10.2.3.3/32
Thanks !
/bala
7 Replies 7
Harold Ritter
Bala,
if you only want the route-map to select and export the one specific prefix, you need to remove "route-target export 114.3.1.1:4" from under the ip vrf configuration and then add "set extcommunity rt 114.3.1.1:4" under the route-map.
Otherwise all prefixes will be exported with this specific RT, whether or not they match the route-map.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Actually, even with the config I suggested, other prefixes will also be exported but without any RT, which will cause them not to be imported anywhere else.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
p.danielsen
Hi Bala,
try looking at this configuration, it uses access-lists insted of a prefix-list, but it works ..
ip vrf ES
rd 12345:10040
export map ES
route-target export 12345:10040
route-target import 12345:10040
route-map ES permit 10
match ip address 20
set extcommunity rt 12345:10053 additive
access-list 20 permit 172.40.1.0 0.0.0.255
Hope i helps you.
/Peter
Peter,
Your configuration adds an extra RT for that one specific prefix that you specify under the route-map but doesn't prevent all of the other prefixes to be tagged and exported with the RT value configured under "ip vrf ES"
Cheers,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
if your intention is to only export a specific network from a VRF, why not to use filters during redistribution and not to insert other networks into MP-BGP?
Regards, Martin
Martin-
The intent is this: the VRF hosts a management site and our customer wants to export only specific routes from the management hub site to the spokes....enough for them to get to the mgmt site. We had cupla options - using ACLs vs prefix-list and chose the prefix list per customer request due to perf reasons (see my last post).
I;m curious to know how you'd control this via redistribution. So under my PE-CE redistribution to my mgmt site, I'd then have to throw away 'other routes' ? I'd end up using route-map there too right ? it'd just be a different place (instead of "export map" under my "ip vrf" then it'd be under say my "router bgp" ??)
Thanks !
/bala
To add to that, I got the impression from our customer that prefix-lists have better performance than access-lists ("uses lesser CPU cycles" is the actual quote though I wonder why....maybe a separate topic)
