directory softkey asks for authorization
Jan 30th, 2007
when softkey of 7941 is pressed, authorization(username & password) is requested. this happenen when I deployed CCM4.1, and CME3.3. how to resolve the issue? Thanks.
gogasca Wed, 01/31/2007 - 08:43
For CCM have you already restarted IIS?
Ran adminutility.exe and resynched all accounts.
If that doesnt help:
1. What exact Version of CCM ? Any SR's ? Engg Specials ?
2. What OS ? Could you run STIVER.exe from C:\sti folder or MCSVER.exe from C:\Utils and
send me the outputs ?
Run UMTrace from command line
- Choose "All Layers" from the "Select the layer" drop down box.
- Check the Trace On check box.
- Choose "Detailed" from the "Trace Level" drop down box.
- In the "Trace file name" text box, retain the default value, i.e. "Preserve Original
Values"
- Then Click "OK" button.
Then go to an IP Phone and press or Directories and upload the latest files from
** C:\dcdsrvr\log folder and
** C:\WINNT\System32\LogFiles\W3SVC1
Stoyan Stoitsev Sun, 02/04/2007 - 23:29
In CCM go to IIS and check on CCMIP properties> directory security> anonymous access and authentication control> click Edit...
You should have Anonymous access checked
And when you click Edit... the user account should be CCMUser
Also in C:\CiscoWebs\IPPhoneServices\CCMCIP the CCMCIP folder should be set for web sharing with Read for Access permissions and Execute for Application permissions.
xiaoliangyue Mon, 02/05/2007 - 11:46
Thanks, guys,
systerm ver: 4.1(3)sr4b
os image: 2000.2.5, os service release: 2000.2.7sr8, os upgrade: 2000.2.7
the original issue should be caused by anonymous user. Right now, the phone doesn't ask for authorization.
perron.v.bruno Thu, 01/15/2009 - 08:28
Need help! I am using SDK on a proxy web server to query an AD ldap directory not integrated with CCM 6.1. Encountering an "Authorization Required!" error.
