Put incoming call on hold
Jan 30th, 2007
We are running Cisco CallManager 4.2 with 7941 and 7961 IP phones and I was wondering if there is a way to place an incoming call directly on hold without having to answer it first.
thanks
justin
Overall Rating: 4 (1 ratings)
gogasca Wed, 01/31/2007 - 08:39
Hi Justin,
You can do it with a Contact Center Application (IPCC) or with Attendant Console using Broadcast Hunting Algorithm.
justin111 Wed, 01/31/2007 - 14:42
Thanks gogasca, will give the broadcast hunting a try.
justin
justin111 Wed, 01/31/2007 - 14:43
Thanks for the response, but I was looking to send callers straight to hold rather than voicemail.
justin
