create cue user
Jan 30th, 2007
I create a user in cue, there's no sub command to configure the password and pin:
se-192-168-30-253(config)# username u2315 ?
create Add the user account
phonenumber Specify a number or extension for the user
phonenumberE164 Specify the E.164 number for the user
How this happens?
rob.huffman Wed, 01/31/2007 - 06:00
Hi Jonathan,
Maybe this will help get you started;
Verify that the users and groups that will have voice mailboxes are configured before configuring Mailboxes.
The following information is required for adding or modifying a user:
Username The user ID. The username must be at least 3 and no more than 32 characters in length. Cisco Unity Express allows only letters, numbers, underscore (_), dot (.), and dash (-) in user IDs. User IDs must start with a letter. Do not use spaces in the username.
(Optional) Full name First and last name of the subscriber. Enter this name in quotation marks (" ").
(Optional) Group Name of an existing group in which this subscriber is a member.
(Optional) Password Password for logging into the Cisco Unity Express GUI. The password must be at least 3 and no more than 32 characters in length. Spaces are not allowed.
(Optional) PIN Personal identification number for logging into the TUI. The PIN must be at least 3 and no more than 16 digits in length.
EXEC mode:
1. username userid [create | delete | fullname [first "first-name" | last "last-name" |
display "full-name"] | group group-name | language "language"| password "password" | pin number]
2. show users
or
show user detail username userid
3. copy running-config startup-config
Configuration mode:
1. config t
2. username userid [create | phonenumber phone-number | phonenumberE164 full-number]
3. exit
4. show users
or
5. copy running-config startup-config
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_administration_guide_chapter09186a0080677969.html#wp1060327
Hope this helps!
Rob
xiaoliangyue Wed, 01/31/2007 - 06:36
Thanks, Rob,
I didn't notice the difference of exec mode and config mode of user creation.
