ASA vs PIX software feature comparison
Jan 31st, 2007
Hi to all, i'm looking for a document about software feature comparison between pix and asa not related to any hardware module.I know asa can do IPS and anti-x with the appropriate module, but what i'm looking is the software differences between asa and pix platform .For example, i know asa is webvpn capable, and pix not.Is this the only differences ?
Many thanks to all
Max
Daniel Voicu Wed, 01/31/2007 - 01:29
Hi Max,
ASA seems to be more application oriented than PIX.
As well, you are right, SSL is the big difference.
Note that for ASA to support SSL users you need a special licence for that.
Check:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddaf25f
http://www.cisco.com/en/US/products/ps6120/index.html
Please rate if this helped.
Daniel
Massimiliano Tognon Mon, 02/05/2007 - 07:04
I found a link with a feature license explanation for all license for asa and pix, and with all the information everyone is able to make a comparison. The differences between pix and asa on software are Webvpn and vpn load balancing (support for asa 5520 and greater).
You can find all the information at this link:
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a008064093e.html
rate if you find ok
