3640-console-connection
Jan 31st, 2007
Hi, I can not see anything on my 3640 router with IOS 12.0 and config register value 0x3922.
Please adivse me console settings for windows-hyper terminal.
glen.grant Wed, 01/31/2007 - 02:31
0x3922
Ignores break
Boots into ROM if initial boot fails
115200 console baud rate
openjunios Wed, 01/31/2007 - 02:35
I did it, still can not see any display..what about flow clontrol,stop bits and flow control?.
Richard Burts Wed, 01/31/2007 - 03:50
The console connection usually is set with 8 bits, 1 stop bit (I have also seen it work with 2 stop bits), and no flow control.
Rick
openjunios Thu, 02/01/2007 - 17:55
It woring with 115200-8-N-1 Combination. Thanks for tips But problems is unable to reset enable secret becuase my config register is 0x 3922, which ignores the BREAK sequence.
How can I reset my enable secret.Thanks in advance.
mohamed.khadr Wed, 01/31/2007 - 10:00
Fist make sure u r on the correct port COM.
Second, the setup is : 9600, 8, none,1, off.
adnan.zafar Wed, 01/31/2007 - 21:48
change the baud rates 1 by 1 n check what is showing in screen
if ASCII characters is shown on 9600 baud rate then check on higher your problem will surely solve
One thing more have u put Console connector in AUX interface or Console interface because some time people forget this things
Hope this may help you
B.Regards
