There is 1 critical problem I?m facing. 1 Cisco 1751 Router is configured for Dial-in. Async interface 1 is connected to Telephone line. Now I connected another local telephone line to Laptop & configure the modem setting same as Router. Now I create the dial-up connection on Laptop & dial the Router phone no. Call is established & It?s asked for Username & Password & verifying it. After some seconds the following error appeared.
?Error 791 Remote computer not responding? & Call is being disconnected.
Pls see the router configuration below. I have done same configuration on 2500 router. It?s working fine. Hope You will be reply soon.
Current configuration : 2015 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$m6Xc$swVAV8EpmJbR6tnVRf2Xm1
memory-size iomem 20
clock timezone IST 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
isdn switch-type basic-net3
chat-script offhook " " "ATH1" ok
username all
username cisco password 0 cisco
interface FastEthernet0/0
ip address 172.17.64.1 255.255.255.224
speed auto
full-duplex
interface BRI0/0
description ***** Connected to Norther Regional Head Quarter *****
ip address 10.10.10.2 255.255.255.252
encapsulation ppp
no ip mroute-cache
no shutdown
dialer string 01126503955
dialer load-threshold 1 either
dialer-group 1
isdn point-to-point-setup
interface Async1
ip unnumbered FastEthernet0/0
encapsulation ppp
no ip mroute-cache
async mode dedicated
peer default ip address pool work
ppp authentication chap
interface Async2
no ip address
encapsulation slip
router eigrp 100
redistribute static
network 172.17.0.0
network 10.10.10.0 0.0.0.3
no auto-summary
no eigrp log-neighbor-changes
ip local pool work 172.17.64.10
ip classless
ip route 172.17.65.0 255.255.255.0 172.17.64.2
ip http server
no ip http secure-server
logging 172.17.14.11
dialer-list 1 protocol ip permit
line con 0
line 1
exec-timeout 0 0
no flush-at-activation
script modem-off-hook offhook
login local
modem InOut
modem autoconfigure discovery
terminal-type type
transport input all
autoselect during-login
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line 2
no exec
transport input all
stopbits 1
speed 115200
line aux 0
line vty 0 4
password 7 151A0D0F082325302C
login
end
