GEC Bundle traffic.
Jan 31st, 2007
We have just configured a GEC bundle between two interfaces on a Cat6509 and 2 x Cat 3550 over a 1GB Link.
So we have
Cat 6509 --- Cat 3550
g9/1 --- g0/1
g9/2 --- g0/2
And I was expecting the flow of traffic between the links to be divided between the 2 links but the attached is what I get.
How can I get it to be more evenly distributed?
a-vazquez Tue, 02/06/2007 - 07:00
Traffic in an EtherChannel is distributed across the individual bundled links in a deterministic fashion. However, the load is not necessarily balanced equally across all the links. Instead, frames are forwarded on a specific link as a result of a hashing
algorithm. The algorithm can use source IP address, destination IP address, or a combination of source and destination IP addresses, source and destination MAC addresses,or TCP/UDP numbers.To set the load-distribution method among the ports in the bundle, use the port-channel load-balance command. Refer URL
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/cmdref/p1.htm#wp1021955
