3750 IOS trouble
jcutler0622
The 3750's act as one switch in stack formation. I have 3 switches stacked, and I have loaded the proper IOS on the first switch and as I begin to stack the switches the IOS is loaded to the 2 other switches as it should be. The problem is below:
Switch Ports Model SW Version SW Image
* 1 26 WS-C3750-24TS 12.2(25)SEE2 C3750-IPBASEK9-M
2 26 WS-C3750-24TS 12.2(25)SEE2 C3750-IPBASE-M
3 26 WS-C3750-24TS 12.2(25)SEE2 C3750-IPBASE-M
Notice the IOS is all the same but only one has the K9 security features. Can someone tell me why this is? I need an answer ASAP and will rate. Thanks!!!!
royalblues
Level 10
Level 10
Friend,
Can you try loading the software from the existing Master to one of the stack memebers
archive copy-sw /destination-system
destination-stack-member-number /force-reload
source-stack-member-number
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swiosfs.pdf
HTH, rate if it does
Narayan
