01-31-2007 06:10 AM
We have devices shown in RME & Common services that are not appearing in DFM.
How do I make sure that all my devices are consistant ?? (ie: whats in RME = DFM)
Scott.
01-31-2007 06:24 AM
You can try adding on of the missing devices to DFM manually. Once you add it, does it go to a known state or does it get stuck in learning or go to a questioned state?
01-31-2007 06:30 AM
I must be really thick because I cannot see how you manually add to DFM, there is not a manual operation for this ??
01-31-2007 06:40 AM
First have a look at DFM - Device Management - Rediscover/Delete
Do the missing devices appear there under Questioned or Unknown? If so, what subcategory do they fall into?
to add them, go to DFM - Device Management - Device Selector and then select devices showing as not in DFM.
02-15-2007 03:28 AM
Are devices that are added to DCR shown in the DFM device selector? Check if the auto sync is enabled so that the devices are added to DFM, if its not enabled please select the devices and add manually to DFM.
Radhika
