Static NAT translation
Jan 31st, 2007
I have a Cisco 1811 router that will be terminating an ISP connection. There will be no VPN tunnel configured. Is it possible to configure one static NAT translation that will be plugged into the switch ports on the 1811 and the other devices plugged in here to not be NAT'd? Basically, I am wondering if when you configure one static NAT translation that the other hosts need to be NAT'd or can they remain completely separate?
jcrussell Wed, 01/31/2007 - 08:31
They can remain separate. You can define a static NAT for something like a mail or web server. Then you can have everything else NAT from a pool or use PAT.
mark.blanchfield Wed, 01/31/2007 - 08:35
Is it possible for the other hosts to not be NAT's at all? I guess the question is if you configure a static translation, does this enable NAT globally or can you still leave other hosts as they are and not NAT them? Thanks for the response.
jcrussell Wed, 01/31/2007 - 08:43
You should be able to leave them with their original addresses. Of course, they will need to use public addresses if they want to connect to the internet.
