3.3.3 to 4.0.1.42 not working on secondary server
I upgraded from 3.3.3 to 4.0.1.42 but still with old Base Image for now:
Cisco Secure ACS 4.0.1.42
Appliance Management Software 4.0.1.42
Appliance Base Image 3.3.1.8
CSA build 4.0.1.543.2 (Patch: 4_0_1_543)
I upraded first my master server, that worked fine (after resolving some problems). When I tried to upgrade the "secondary" server, I get the following (in CLI because WEB does not work because services are not started):
CSAdmin starting
CSAuth starting
CSDbSync starting
CSLog stopping
CSMon starting
CSRadius starting
CSTacacs stopped
CSAgent stopped
Appliance upgrade in progress...
The "upgrade in progress" is for almost 60 minutes now.
How do I recover the Web access?
Vivek Santuka Wed, 01/31/2007 - 15:01
Issue a download on the CLI and see if that clears the "upgrade in progress". If it clears it then reboot the server once.
In 4.0 upgrade the CLI at times may keep showing "upgrade in progress" even though the upgrade is completed.
Vivek
atomas001 Mon, 02/05/2007 - 07:08
Hi.
OK, it's not anymore with "upgrade in progress" and CPU went down from 100% to 0%. Some services are still in these states:
CSAdmin stopped
CSAuth stopped
CSDbSync starting
CSLog starting
CSMon starting
CSRadius starting
CSTacacs stopped
I tried stoping/starting/restarting them without success, getting this message:
xxxxxxx> restart all
CSAdmin is not running
CSAuth is not running
Error: Failed to stop service: rc = [1052] The requested control is not valid for this service.
So I tried to do a shutdown. After coming back up, CPU is back to 100% and services look this way:
CSAdmin starting
CSAuth starting
CSDbSync starting
CSLog stopping
CSMon starting
CSRadius starting
CSTacacs stopped
