Resetting configuration on Catalyst 2900 XL
Jan 31st, 2007
How do I reset the configuration of a Catalyst 2900 without going through the command prompt?
m-haddad Wed, 01/31/2007 - 16:36
If you have an IP address on the 2900 Switch you can use your browser and point it to the URL address http://Switch_IP_address
THere you can reset the configuration.
However, if the switch does not have IP address of the web installed and enabled you have to use the console.
Once in the console issue the below commands
enable
"enter enable password"
wr er
reload
Let me know if this helps,
Appreciate your rating,
