LMS 251 Installation Problem
birengandhi
We are installing LMS 251 on Solaris 9.
During the CS 303 Install, we got this error message. What do you recommend, we should do? Proceed, Abort OR Uninstall?
Finished: Wed Jan 31 11:25:36 EST 2007
===============- Software Installation Tool Completed -==============
===================- Possible Warnings/Errors Encountered -===================
WARNING: Exiting installation beyond this point might result in system instability.
pkgadd: ERROR: unable to merge package and system information
ERROR: garbled entry
ERROR: pathname: Unknown
ERROR: problem: unknown ftype
ERROR: Package verification failed : CSCOmd aborting.
David Stanford
Looks to be something wrong with the partitions on Solaris. Are there any bad blocks in /var or /opt
LMS isn't going to work properly...I would recommend uninstalling it, best to use the clean_system.sh script which is found at http://www.cisco.com/warp/customer/477/RME/LMS_Install.html#uninstallSol
Then check to make sure the partitions and disk are ok, as well as the required Solaris patches installed.
