CCM 5 Disaster Recovery System Administration - Path
Jan 31st, 2007
As CCM5 is run on Linux platform, and Im not familiar with Linux. Any ideas when we do our backup at the " Disaster Recovery System Administration ", where is the recommended path to do the backup.
Thanks.
rob.huffman Wed, 01/31/2007 - 09:37
Hi OU,
Maybe this will get you started;
Configuring a Storage Location
Before using the Disaster Recover System, you must configure the location where you want the backup file to be stored. Perform the following steps to configure the storage location.
Procedure
Step 1 Navigate to the Disaster Recovery System. Log in to Cisco Unified CallManager Administration, choose Disaster Recovery System from the Navigation menu in the upper, right corner of the Cisco Unified CallManager Administration window, and click Go.
The Disaster Recovery System Logon window displays.
Step 2 Log in to the Disaster Recovery System by using the same Administrator username and password that you use for Platform Administration.
Step 3 Navigate to Backup>Storage Location. The Storage Location window displays.
Note You can configure the number of backup sets that are stored on a network directory.
Step 4 Choose one of the following storage destination options and enter the appropriate field values:
Tape Device Stores the backup file on a locally attached tape drive. Choose the appropriate tape device from the list.
Note You cannot span tapes or store more than one backup per tape.
Network Directory Stores the backup file on a networked drive that is accessed through an SFTP connection. Enter the following required information:
Server name: Name or IP address of the network server
Path name: Path name for the directory where you want to store the backup file
User name: Valid username for an account on the remote system
Password: Valid password for the account on the remote system
Note You must have access to an SFTP server to configure a network storage location. The SFTP path must exist prior to the backup. The account that is used to access the SFTP server must have write permission for the selected path.
Step 5 To update these settings, click Save.
Note For network directory backups, after you click the Save button, the DRS Master Agent will validate the selected SFTP server. If the user name, password, server name, or directory path is invalid, the save will fail.
Step 6 Continue with either a manual or a scheduled backup.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide09186a00806c51cb.html#wp173471
Hope this helps!
Rob
