Http enabled on 3650 switch
Jan 31st, 2007
I'm uploading a new image to a 3650 switch from c3560-ipbase-mz.122-25.SEB4 to c3560-ipbasek9-mz.122-25.EB4.bin image and now I can't brouse the switch but before the uplad I could...any sugestions?
I found the k9 image adds some different defaults to a few things, ip http server/secure-server to name a few.
Take a look at the running-config and look for a line spelling out http authentication, set it to what you want, confirm ACLs not killing you, or local auth when none is configured, and of course the IP general set up.
hambone8204 Wed, 01/31/2007 - 09:35
It's right out of the box..No ACL etc, See file.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.192.192.1 255.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
Switch#
glen.grant Wed, 01/31/2007 - 09:33
Did you get the tar file image , this has the needed html files , if you just downloaded the .bin file it probably won't work .
glen.grant Wed, 01/31/2007 - 16:30
will look like something like this c3560-ipservices-tar.122-25.SEB4.tar .You then hav to use the archive command I believe , not real familiar with this as we never use the HTML web based mgt. feature , CLI only.
hambone8204 Thu, 02/01/2007 - 06:51
Yes, I agree on the CLI however, Some of the team member perfer not to ust the Cash Line Interface.. I found the image file and noted once I get it c3560-advipservicesk9-mz.122-25.SEB4? It converts the tar file.. Is that where you mentioned "Archeive command" comes in?
