Cisco ACS Server
Answered Question
Jan 31st, 2007
I have at present a Cisco ACS server 3.3. I want to upgrade the server to latest version and also cluster it with another one so that we could have a redundant infrastructure as if one fails the other one takes over ..
CAn you provide a suitable solution for this ?
Correct Answer by Vivek Santuka about 9 years 8 months ago
The Latest version is ACS 4.1. You can upgrade from 3.3.3 build 11 directly to 4.1.
Then you can install another ACS 4.1 on different machine and setup replication between these two. This way you will have to make changes only on one ACS and the secondary will automatically get updated.
Once these two are set, you can define both of these server as Radius/Tacacs server on the devices and there would be a redundancy.
Vivek
Overall Rating: 4 (1 ratings)
Correct Answer
Vivek Santuka Wed, 01/31/2007 - 14:59
Vivek
vinothdhanapal Thu, 02/01/2007 - 02:27
Hi Vivek
Many thanks for the information I shall try to do it and reply you back if I have any issues...
Vino
