ASA5510 VPN/NAT
Hello all,
I am having an issue with one of our VPN's that was recently setup and I am seeing ICMP errors. When I send a simple ping test to the destination IP, I am seeing the following messages while running the debug log-viewer:
208.x.x.x|Built ICMP connection for faddr 172.x.x.x/0 gaddr 208.x.x.x/512 laddr 208.x.x.x/512
6|Jan 31 2007|17:37:27|302020|172.x.x.x|10.x.x.x|Built ICMP connection for faddr 172.x.x.x/0 gaddr 208.x.x.x/512 laddr 10.x.x.x Jan 31 2007|17:37:27|609001|172.x.x.x||Built local-host internet:172.x.x.x
Denied ICMP type=0, code=0 from 172.x.x.x on interface internet
4|Jan 31 2007|17:37:27|313004|||Denied ICMP type=0, from laddr 172.x.x.x on interface internet to 208.x.x.x: no matching session
I do not have access to the firewall at the other end of the VPN, however I did contact the admin and he verified that the packets successfully came in and out. So I am not sure why I am getting the Denied ICMP and No Matching session error. Any help would be appreciated.
JD
talisman1310 Wed, 01/31/2007 - 23:01
What is the device at your site and the remote dite?
When using a 7600series router with a VAC card you can create a loopback with the IP configured in the encrytion domain and try to ping the destination host.
ping source loopback
