detect Proxy on the network
Jan 31st, 2007
Is there a way for me to detect if a proxy server or computer was install on the network?
Overall Rating: 3 (2 ratings)
johnisccp Fri, 02/02/2007 - 06:14
Michel,
Thanks for your reply but I do not wish to configure or install a proxy server. I want to find if someone who is not authorize to setup a proxy, setup one on the network.
yjdabear Fri, 02/02/2007 - 12:02
Well, if you have some guesses/assumptions to the characteristics or flavor of the unauthorized proxy in *active* use, you can have measures like having a NetFlow reporting tool/RMON II probe alert you on certain traffic pattern (say, assuming all TCP port 3128 traffic are Squid Cache proxy) going over a certain rate or volume. For a proxy that's not talking much, what can you do? Sweeping port-scan your own IP ranges?
