PIX 7 - Multiple remote VPN sessions from same public IP
Answered Question
Jan 31st, 2007
Here is my problem:
Employee A and employee B make VPN connections to the same PIX with their Cisco VPN clients. Both employees are behind the same NAT device, hence have the same public IP address.
As soon as the second employee initiates the VPN connection, the first employee is disconnected.
I have a similar situation with a PIX version 6.x, and this does not occur. Both employees can connect at the same time, with the same credentials.
Here's the remote access VPN configuration that I use:
group-policy gpolicy attributes
dhcp-network-scope 10.X.X.X
vpn-simultaneous-logins 5
vpn-tunnel-protocol IPSec
ipsec-udp enable
split-tunnel-policy tunnelspecified
split-tunnel-network-list value splitTunnelAcl
user-authentication enable
client-firewall none
username remoteuser password remotepass
username remoteuser attributes
vpn-group-policy labtronix
vpn-simultaneous-logins 2
group-lock value vpngroup
tunnel-group vpngroup type ipsec-ra
tunnel-group vpngroup general-attributes
address-pool ip_pool
default-group-policy gpolicy
Any and all input is appreciated.
Thanks.
Correct Answer by acomiskey about 9 years 8 months ago
Most likely nat-t problem
add "isakmp nat-traversal" to pix
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Wed, 01/31/2007 - 13:23
