Product help
Jan 31st, 2007
I have a Project with the following equipments and requirements,a Nokia GSM switch,which i need to inteconnect with one PBX using ISDN-PRI.The Nokia switch don't support signaling ISDN-PRI at this moment, only ISUP and the PBX ISDN-PRI.
am looking for Cisco equipment to do the interworking, like follow topology:
Nokia_Switch<-----isup------>CISCO<---ISDN-PRI---->PBX
Which cisco Product can i use to achieve this.
Thanks in advance
