Cisco ASDM on my Linux Laptop
Jan 31st, 2007
I am running Firefox 2.0 with Java 1.5 on my Fedora Core Laptop. When I log into the ASDM Webpage and it finishes loading the configs I only get a blank page. Basically nothing is showing up in the window. I have to force out the connect with a kill command.
Has anyone gotten the web ASDM java version to work on their Linux Laptop? If so what is the version combo of browser and java?
Thanks.
Pete
Benjamin Story Tue, 02/20/2007 - 06:25
I'm running Firefox 2.0 and Java 1.5 on Ubuntu 6.10 and the ASDM is working great.
xephael Tue, 02/20/2007 - 14:53
I've used ASDM on Solaris just fine with Firefox... Brian probably nailed down what your problem is.
enkrypter Thu, 09/06/2007 - 04:40
I have the same problem.
I run ubuntu fiesty and java 6 with FireFox. As soon as I switched back to the default gnome window manager i was back in business. Just simply disable window effects and you will be fine.
Tom
HELGE MEYER Wed, 12/19/2007 - 04:19
i have change the java version 1.5 to the original Sun Java 1.5.2.
After you install the sun java, you can change with the "alternative" command the default java environment.
After this changes it's works fine on my laptop with Fedora 7 and FF2..
Helge
