CSM trunks oversaturated?
Answered Question
Jan 31st, 2007
We have a CSM 4.1.6 in Hybridmode we noticed on the switch that the top talkers were maxing out 100% on one of the 4 trunks to the CSM it randomly changes ports steadily @ 100%. So my question is why doesnt the CSM use all trunks equally?
Correct Answer by marcin.mazurek about 9 years 8 months ago
I'm using native mode but in Your case maybe this will help:
set port channel all distribution {ip | mac | session} [source | destination | both]
br
Overall Rating: 5 (1 ratings)
marcin.mazurek Wed, 01/31/2007 - 14:28
try to choose different balancing method aproptiate for Your traffic:
port-channel load-balance ?
dst-ip Dst IP Addr
dst-mac Dst Mac Addr
dst-port Dst TCP/UDP Port
mpls Load Balancing for MPLS packets
src-dst-ip Src XOR Dst IP Addr
src-dst-mac Src XOR Dst Mac Addr
src-dst-port Src XOR Dst TCP/UDP Port
src-ip Src IP Addr
src-mac Src Mac Addr
src-port Src TCP/UDP Port
hth
Marcin
jcmattos1 Wed, 01/31/2007 - 14:52
Thanks for the quick response Marcin but it doesn't seem to like the command on CATOS both SUP & MSFC. Is there another way to apply it?
Correct Answer
marcin.mazurek Wed, 01/31/2007 - 14:57
br
