Web Auth on catalyst 3750
Jan 31st, 2007
Hi, I'm using catalyst 3750s and cisco acs 4.1 to authenticate clients but I need help. The docs tell how to configure basic web auth on ports but I need more details as I'm very new to this. For example, do I need an external webserver to serve the login page? Does anyone have an example of a login page code/script to share? How do I configure the web redirection?
I'll appreciate any help. Thanks
scadora Wed, 01/31/2007 - 21:37
You don't need an external webserver and you don't need to configure redirection. When you configure web auth, the 3750 itself acts as a webserver and presents a default login page to the end user to enter his/her credentials.
Hope that helps.
Shelly
vjokhoo Thu, 02/01/2007 - 04:51
Ok, I may not have explained myself properly. This is required to give clients Internet Access but only if they authenticate first against a radius server (The ACS) Not all clients will have 802.1x clients so I am considering the web authentication method. So when a client connects his laptop to the switch via ethernet he gets an IP Address via DHCP but then needs to authenticate against a radius server before he can get access to the Internet.
I have configured as to the directions in the documentation. I am getting the IP Address via DHCP but when I launch a browser nothing happens (I am of the opinion that I should get some default login page) The only login page I get is if I point my browser to the switch IP Address but this only grants me access to the switch itself. This is my config:
aaa new-model
aaa authentication login default local group radius
aaa authorization network default local group radius
aaa authorization auth-proxy default group radius
aaa session-id common
switch 1 provision ws-c3750-24ts
system mtu routing 1500
ip subnet-zero
ip routing
ip admission name cwc2007 proxy http
ip dhcp excluded-address 192.168.10.1
ip dhcp pool cwc2007
network 192.168.10.0 255.255.255.0
dns-server 196.3.132.1 196.3.132.4
default-router 192.168.10.1
domain-name tstt.net.tt
ip device tracking
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Loopback0
ip address 10.0.0.1 255.255.255.255
interface FastEthernet1/0/1
switchport access vlan 10
switchport mode access
ip admission cwc2007
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
switchport access vlan 101
interface FastEthernet1/0/24
switchport access vlan 100
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan100
ip address 10.1.1.3 255.255.255.0
interface Vlan101
ip address 201.238.75.157 255.255.255.252
ip classless
ip http server
ip http secure-server
radius-server attribute 8 include-in-access-req
radius-server host 192.168.1.60 auth-port 1645 acct-port 1646 key ****
radius-server source-ports 1645-1646
radius-server vsa send authentication
control-plane
Maybe I am missing an ACL or something?
scadora Thu, 02/01/2007 - 07:56
Right, you need an ACL. Otherwise all traffic is allowed through the port and not intercepted for web auth. Try adding something like this:
ip access-list extended POLICY1
permit udp any any eq bootps
deny ip any any log
ip access-group POLICY1 in
...etc
Hope that helps.
Shelly
