Wrong software for this hardware (3660)
Jan 31st, 2007
Hi guys, we are having some troubles with this 3660 router. We just installed 2 internal Flash cards of 8 Mb each. After trying to upload an IOS (an IOS that we are using in another same model router, we keep getting the "Wrong system software for this hardware" message. You can check this:
System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1) Copyright (c) 1999 by cisco Systems, Inc.
C3660 processor with 65536 Kbytes of main memory Main memory is configured to 64 bit mode with parity disabled
rommon 1 > xmodem -c c3660-is-mz.122-6.bin Do not start the sending program yet...
File size Checksum File name
14998716 bytes (0xe4dcbc) 0x2de4 c3660-is-mz.122-8.T5.bin
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c3660-is-mz.122-6.bin ...
Erasing flash at 0x30fc0000
program flash location 0x30aa0000
Download Complete!
program load complete, entry point: 0x80008000, size: 0xaa50d4 Self decompressing the image : #################################################
################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0000B3 0X0009FC00 Dual Port Fast Ethernet
0000CC 0X00164794 High Density Voice Port Module
00003B 0X001AA000 Two CE1 - Unbalanced (75 Ohm - Coax)
0X00280000 OIR memory
0X000F3BB0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00932F44
If any of the above Memory Requirements are "UNKNOWN", you may be using an unsupported configuration or there is a software problem and system operation may be compromised.
Rounded IOMEM up to: 10Mb.
Using 15 percent iomem. [10Mb/64Mb]
rommon 1 >
Can you guys help? Thanks in advance!!
Omar Montes
ankurjain05 Wed, 01/31/2007 - 22:08
Try using different IOS of different feature set and version.
and try to resit the flash and ram again on the motherboard of the router.
That might help
s.conway Wed, 01/31/2007 - 22:26
What is the bootstrap version on the router that you're already running this code level 12.2?
This router is running System Bootstrap, Version 12.0(6r)T,
Maybe you need to upgrade the bootstrap code first.
