01-31-2007 11:09 PM
I am facing a problem in Topology services which is as below:-
I have a managed 2950 switch connected to a 6509e. I can see all devices & links properly in topology services. For testing purposes i connected another 2950 (which is also managed) to existing 2950 via a cross over cable as trunk, configured for SNMP,cdp etc. Now this device can be seen throuh chassis view and topology services.If i power it off the icon becomes red & when powered on it becomes green within 1.5 minutes. But the problrm is that the link connecting the two 2950's stays solid red (even when powerd on). I manually ran a device discovery once again and still the problem persists. Both the devices can see each other via cdp, ping etc. when i did a path analysis layer 3 is successful but layer 2 is shown as failure.
How can this be? The devices are directly connected (nothing in between).I use LMS 2.6
Pls give some ways to overcome this.
Thanks and Regards
Sonu
01-31-2007 11:51 PM
Since we cannot see the objects the Campus database holds on the devices the best option is to delete the link, select the 2 devices and run a data collection for these 2 devices.
Cheers,
Michel
02-05-2007 10:50 AM
In "Schedule data collection" I checked & set the "Poll periodically at these intervals" to 4 minutes, so that if any device is down it can be detected within this timeframe. But this is not the case & it takes hours for the icons to change colour. [ Full device discovery & data collection happens once a day ]. Only when i do a data collection manually does the changes get upadtes[ color changing from red to green or vice versa ]. I need the changes to be updated dynamically & as soon as it happens. I am totally at a loss since all settings appear to be correct.Can someone explain please, as i am stuck on this issue!.
Regards & Thanks
Sonu
02-05-2007 10:47 PM
Ciscoworks Campus Manager was not designed to do any realtime monitoring. DFM is the only realtime component in Ciscoworks.
I believe to get the best results from Campus you should lower the "Poll Interval" in the "Data Collection Schedule". It is by default every 2 hours.
This only checks the existing devices and interfaces.
I also feel it can't be a big deal to take the events from RME's syslog and DFM, and to have these events change the color of a device in Campus. I spoken to several people at cisco about this and they agree but I don't see anything moving there.
I guess the focus is on other projects that could bring in more money.
Cheers,
Michel
