How to two DID different bloks work in callmgr and voice gateway
Feb 1st, 2007
I have trouble to install two different did blocks old did block(6828 7100 to 6828 7699 have been working for two years. Add new did block 6829 3000 to 6829 3199 recently. The PTT gateway 3745 router one ip address in Call mgr gateway has two isdn pri lines. PTT indicated now ISDN pri line 1 is for old did block and pri line 2 is for new did block. However, the gateway router selects the two lines i.e. s1/0:15 & s2/0:25 randomly. Thus, the caller shows the prime number if the call throws to the wrong line. How to fix the call throws to the right ISDN pri line.
Comments from PTT
Can the CallManager throw the calls to the respective lines? For example
for 6828 7100 -7699 it should throw to tp1.01 jgp1348 uam1-01 (ET 1081)
and for 6829 3000 3199 to tp1.02 jgp1348 uam1-01. I am sure this can be
done right? Otherwise the other range (6823 7000 - 7099) would not work
also. If you can ask your vendor on this
