NAT of source- and destination addresses
Good day folks,
I have tried hard to find examples for the following scenario without luck. Here is my IOS (not PIX) problem:
Because of overlapping addresses problems, I have to allow internal clients to connect to servers through a router with static NAT. This would be a simple outside->inside NAT.
The problem is, that those packets with changed destination address arriving on the inside interface should also be
NATed to the interface's address
or a loopback interface or whatever.
So a connection packet from the client
to a server would need to have both
SA and DA changed.
I tried with ip nat inside + ip nat
outside combinations in whatever directions but either out->in or
in->out is failing and does not
traverse through the router.
In case you need more information
regarding this special case please let
me know. Otherwise, I would be very
happy if someone could provide me
either with a "simple, follow this
link and check it out" or with a
"forget it" (which I am not expecting :-)).
Thank you very much in advance and
cheers
Sascha
brispin Fri, 02/09/2007 - 06:19
This document demonstrates how you can use Network Address Translation (NAT) for overlapping networks. Overlapping networks result when you assign an IP address to a device on your network that is already legally owned and assigned to a different device on the Internet or outside network. Overlapping networks also result when two companies, both of whom use RFC 1918 IP addresses in their networks, merge. These two networks need to communicate, preferably without having to readdress all their devices.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f30.shtml
