IP Cef load-sharing query
Answered Question
Feb 1st, 2007
I have a MLS with 2 links that advertise the default route. IP cef is enabled on a per-destination basis:
0.0.0.0/0, epoch 3, RIB, refcount 6, per-destination sharing
Why, then, when one of the links had a fault and was effecively down (not passing default traffic but still advertising the link), when I pinged a route that would take the default, e.g. 192.168.12.9, I got the following:
3750A#ping 192.168.12.9
Sending 5, 100-byte ICMP Echos to 192.168.12.9, timeout is 2 seconds:
This looks like per-packet sharing to me, or have I misunderstood?
Thanks, J
Correct Answer by Richard Burts about 9 years 7 months ago
You are seeing the difference between what IOS does for traffic being forwarded THROUGH the router and what IOS does with traffic generated BY the router. Traffic being forwarded through the router does perform per destination. But traffic being generated by the router (like your ping) will do per packet sharing.
Rick
Overall Rating: 5 (2 ratings)
Correct Answer
Richard Burts Thu, 02/01/2007 - 03:16
Rick
Richard Burts Thu, 02/01/2007 - 07:40
Narayan
Anything generated by the router itself (including extended ping) is process switched and will packet by packet load share.
Rick
