Cisco Pix 525 replacemnet assistance
Feb 1st, 2007
i wish to replace a cisco pix 525 please can someone give me a reccommendation of the next best thing. I have a company with a 1000 users
andrew.burns Thu, 02/01/2007 - 02:58
The PIX isn't yet End-of-Sale, and most new features are available by upgrading to the latest vrsion of software (version 7).
If you wanted a like for like upgrade (maybe you want a CSC or IPS module?) then something like an ASA 5520 would probably fit the bill, but it really depends on what your requirements are.
Andrew.
network_team Thu, 02/01/2007 - 03:05
Thanks the pix we currnetly have is struggling with overrunns and dropped packets consistanly. it is connected to a gigabit switch but only runs a 100 meg due to the firewall. we are not hitting 100 meg traffic but cisco have said the dropped packets are due to the amount of traffic it trys to process in a short period of time. Is to ASA interface and ios similiar to Pix cisco 525
gagansethi Mon, 02/05/2007 - 15:07
If you do not have interface constraint then you can upgrade the pix 515 with 3 giabit interfaces in the available slots. Else if you are planning to move on ASA, then 5520 should be a ideal choice for your env. Though as mentioned above i would also suggest to give it a shot & upgrade the existing PIX 525 to IOS version 7.2.x 7 test the performance.
gagan
