dlsw over ipsec
Answered Question
Feb 1st, 2007
Hi all,
someone know if dlsw can work over ipsec in the same router?
regards
Diego
Correct Answer by calopez2 about 9 years 7 months ago
Hi Diego,
DLSW works over IPSEC.
Here is a sample config.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093f71.shtml
I hope this helps you !
Carlos.
Overall Rating: 4 (2 ratings)
mvieiradacunha Fri, 02/02/2007 - 04:33
Is there any one that knows if there are possible caveats on running DLSW-Ethernet over firewalls?
thank you,
mauricio cunha
