BGP load Balance
Feb 1st, 2007
Hi;
I have setup where 2 CE router will be connecting to PE routeres like this ;
CE1--PE1
CE2--PE2
how BGP will run between these 4 routers and it will be to load balance ?
Thx
Jon Marshall Thu, 02/01/2007 - 05:15
This is what we have at some of our sites where we connect to an SP MPLS cloud.
Between CE1 and PE1 - EBGP
CE2 to PE2 - EBGP
PE1 -> PE2 - IBGP
We use MED (Multi exit discriminator) on our CE routers to influence how traffic routes into us. We advertise half our subnets out from CE1 and the same half on CE2 but with a different MED and vice - versa. This way you use both links for incoming traffic.
Jon
