disable CPD on IP phones
Feb 1st, 2007
I just want to know if it's possible to disable CDP on IP phones.
If yes, is there a procedure?
gogasca Thu, 02/01/2007 - 08:32
I am affraid is not possible to disable CDP on the phone itself, it has to be done on the
port the phone is attached to. Please enter command "no cdp enable" and that should do
it.
anatsira Thu, 02/01/2007 - 08:38
Thanks for your reply.
I know i can disable CDP from cisco switch but our IP phone are not connected to cisco switch.
