Cisco Catalyst 2950 Flash Memory
Feb 1st, 2007
I have a Cisco Catalyst 2950 but when I examine the Flash memory the amout of free memory does not seem correct, e.g.
C2950_Swithch#sh flash
Directory of flash:/
2? -rwx???????? 109? Mar 01 1993 00:01:55 +00:00? info
3? -rwx???????? 270? Jan 01 1970 00:01:39 +00:00? env_vars
4? -rwx???????? 916? Mar 01 1993 00:00:19 +00:00? vlan.dat
5? -rwx??????? 1048? Oct 15 1994 18:12:59 +01:00? multiple-fs
6? -rwx??????? 8387? Oct 15 1994 18:12:59 +01:00? config.text
7? -rwx???? 3086328? Mar 01 1993 00:03:35 +00:00? c2950-i6q4l2-mz.121-22.EA2.bin
8? drwx??????? 3968? Mar 01 1993 00:04:08 +00:00? html
341? -rwx???????? 109? Mar 01 1993 00:04:36 +00:00? info.ver
342? -rwx????????? 25? Oct 15 1994 18:12:59 +01:00? private-config.text
7741440 bytes total (3161600 bytes free)
The total memory in use plus the free memory equals 6262651 Bytes and not 7741440 bytes as indicated in the output.
What has happended to the other 1478789
bytes and can I release it ?
dabrooks Thu, 02/01/2007 - 08:59
Issue resolved
Turns out that the HTML is a directory and cd to it and found a load of files in this directory which accounted for a large proportion of the missing flash.
The HTML directory files are used to support the Cluster Management Suite. So if no access is required from a Web Browser but just CLI is used then these files can be removed to free up Flash.
The HTML files are factory installed, but are also installed if the switch is upgraded using a .TAR file which extract the .BIN file and a load more files into the HTML directory. Alternatively if no CMS is required then you can just download a .BIN file to upgrade a switch.
