3550 image.
Feb 1st, 2007
Hi All,
How do I copy 3550 image to tftp server from flash as normal copy flash tftp is not working.
sh flash is showing image with drwx.
whatz the syntax for copying the image.
Thanx in advance.
Rgds,
Rajesh
aperez2004 Thu, 02/01/2007 - 07:22
Thats a directory and to transfer it you need to make it into a tar file. If you just want the image try this:
#dir flash:dirname
#copy flash:dirname/image-name tftp://IP Address
That should work if you do not want to copy all the directory.
rajeshk200_2 Thu, 02/01/2007 - 07:46
Thanks for the response
5 -rwx 0 Mar 1 1993 00:04:40 +00:00 env_vars
6 -rwx 3736 Aug 12 2006 10:13:29 +00:00 vlan.dat
8 drwx 128 Mar 1 1993 00:04:26 +00:00 c3550-ipbase-mz.122-25.SEB
7 -rwx 98 Jun 26 2006 11:05:20 +00:00 private-config.text
360 -rwx 10818 Jun 26 2006 11:05:20 +00:00 config.text
How do I find dir name from the above .
Rgds,
Rajesh
royalblues Thu, 02/01/2007 - 07:49
Friend,
Look at row number 3
The "d" before the rwx refers that it is a directory.
Narayan
aperez2004 Thu, 02/01/2007 - 10:15
c3550-ipbase-mz.122-25.SEB is a directory.
This command is to display the files in the directory:
#dir flash:c3550-ipbase-mz.122-25.SEB
Once you find the name of the image, that might look like this, c3550-ipbase-mz.122-25.SEB.bin (NOTE: I am assuming that's the name if the image).
#copy flash:c3550-ipbase-mz.122-25.SEB/c3550-ipbase-mz.122-25.SEB.bin tftp://IP address where the tftp is running.
