Do_Not_Call table
Feb 1st, 2007
Outbound option is working fine and I can import do_not_call list and outbound campaign will not call numbers I import from do_not_call text file. Everything is working as it suppose to work. Problem is, I can't find do_not_call (or anything similar) table in the database, or on the server as matter of fact.
It should be on the LoggerA in instance_baA database, right?
Roman
Romanilic Mon, 02/12/2007 - 00:01
As I said, there is no Do_Not_Call table in the _baA DB on the loggerA. Yet everything is working as normal and described in the pdf documentation. ???
Romanilic Tue, 02/13/2007 - 23:37
Dialer database?
Where would that database be located and how it would be called?
