ip access-group IN vs OUT
t.khan
I am trying to understand the difference between adding an ACL to an interface with the ip access-group in ip access-group out statement. I have 'in' on one interface, and 'out' on another, and they seem to behave differently. Both of the interfaces end up going out to the internet. A firewall allows the 192.168.3.0/24 range out to the internet. So the 192.168.150.0/24 network gets NAT'd to 192.168.3.100-150 (Overloaded), and the 192.168.3.0/24 interface just keeps the same IP.
See Below:
interface Ethernet1/0
description Lab Network 192.168.150.x
ip address 192.168.150.1 255.255.255.0
ip access-group LAB_ACL in
ip nat inside
full-duplex
ntp disable
<-- cut -->
ip access-list extended LAB_ACL
remark
remark #######################################################
remark
permit ip 192.168.150.0 0.0.0.255 host 4.2.2.1
permit ip 192.168.150.0 0.0.0.255 host 4.2.2.2
permit ip 192.168.150.0 0.0.0.255 65.200.222.0 0.0.0.63
permit ip 192.168.150.0 0.0.0.255 65.200.10.0 0.0.0.255
remark
remark Deny all
deny ip any any log
interface FastEthernet0/1
description Corporate NAT Interface
ip address 192.168.3.2 255.255.255.0
ip access-group ACL_allowed out
ip nat outside
speed 100
full-duplex
<-- cut -->
ip access-list extended ACL_allowed
remark
remark Deny standard microsoft ports
deny tcp any any eq 135
deny tcp any any eq 137
deny tcp any any eq 138
deny tcp any any eq 139
deny udp any any eq 135
deny udp any any eq netbios-ns
deny udp any any eq netbios-dgm
deny udp any any eq netbios-ss
deny tcp any any eq 445
deny udp any any eq 445
remark
remark Permit only traffic with local network
permit ip 192.168.3.0 0.0.0.255 any
remark
remark Deny all
deny ip any any log
rdessert
The difference in applying an ACL in or out is pretty easy. When you apply an ACL "in", the router examines all traffic it RECEIVES on the interface against the ACL.
When you apply an ACL "out" on an interface the router examines any traffic attempting to leave that interface against the ACL.
Also, I take it that your firewall is connected to your interface FastEthernet0/1. ANd also that you are NATing the 192.168.150.0/24 to 192.168.3.100-150 (Overloaded) on this router?
I imagine you are using NAT or PAT on the firewall for 192.168.3.0/24 traffic to access the internet. If you do not want your 192.168.150.0/24 traffic to go to the internet, I suggest removing the NATing on the router.
